#271
Post
by Smoker » Fri Dec 22, 2017 7:56 pm
Ron57 wrote:Hi Pete,
Sorry to hear about the cancer hopefully you'll be able to keep your project going.
Didn't realise you needed the top case as well, all packed up DHL picking it up tomorrow
should see it next week sometime.
Cheers Ron.
Thanks very much, Ron!
Got this titanium bolt for the rear shock mount. Need to add more threads and cut the length. Will make the 2 engine mounting bolts to match this one. The OD of the flange is .667" and I found some 17mm (.669") rod. Waiting for the titanium to arrive.
Smoker on Sat Apr 21, 2018 11:33 pm, edited 1 time in total.
tacky1
#272
Post
by tacky1 » Sat Dec 23, 2017 7:01 pm
Pete, Did you ever get sorted for the tank cover, I have a kit here and Im sure there is a cover in it.
I'm out of the country though till Jan 10th if you don't mind waiting
#273
Post
by Smoker » Sat Dec 23, 2017 7:14 pm
tacky1 wrote:Pete, Did you ever get sorted for the tank cover, I have a kit here and Im sure there is a cover in it.
Thanks! Was just going to post this:
Tank cover from silverstrom. Much appreciated. Will try to do something interesting with it.
Hope the rusted tank isn't too rusted.
#274
Post
by silverstrom » Sat Dec 23, 2017 9:59 pm
Happy to help Pete.
If I can be of further assistance please let me know.
John
#275
Post
by Smoker » Fri Jan 05, 2018 6:35 pm
Was looking at the tank cover and remembered the small fuel cap/filler I got for the Motard project.
Perfect fit for the aluminum fuel tank on this bike. 2mm gap between the cap/filler and the tank cover.
The black/black version would be good for this bike:
#276
Post
by Smoker » Sat Jan 06, 2018 7:50 pm
So unfamiliar with this bike. Missed the upper rear engine mounting bolt.
Now ordered with a titanium nut. All bolts need adjustment on the threads and length.
The titanium bar arrived and is now at the machine shop to cut the two long engine mounting bolts.
#277
Post
by Smoker » Mon Feb 05, 2018 6:20 am
Whether I use the OEM tank, or the Chinese tank cover, I need to have some tank brackets.
Trying not to pilfer parts off the complete RZ500 (yet). Already have the rear bracket. Searching for a front bracket.
Thinking about blasting and powdercoating the brackets. New rubber dampers are still available. Will fabricate new collars and square plates out of 6061 aluminum and color anodize. Already ordered grade 5 titanium rod to make a clevis pin for the rear bracket. Will also get titanium bolts and anodized aluminum washers.
Got some aluminum to make the square plates and noticed the OEM plates are about 3mm to short to cover the dampers. Will correct the size on the new plates.
Smoker on Sun May 20, 2018 10:48 am, edited 1 time in total.
#278
Post
by Smoker » Mon Feb 05, 2018 9:09 am
Will start getting measurements for custom triples.
#279
Post
by Smoker » Wed Feb 07, 2018 6:58 am
Have to decide on a method for chopping the rusted out fuel tank. Still smells like old gas.
Definitely don't want to blow up. Already have enough problems going on.
Thinking about chopping it with a manual hacksaw. Never seen sparks when I've used one in the past.
Then, maybe once it's open and aired out, I could cut it closer with an angle grinder.
BigGuy
#280
Post
by BigGuy » Wed Feb 07, 2018 9:05 am
This might be a PITA but I have had success with securing the tank and filling it with water (as full as you can without it impairing your repair) close to the repair spot. If you do go this way obviously there is a danger of working with water and hydro. Good luck either way you go sir.
Shake "N" Bake!
#281
Post
by silverstrom » Wed Feb 07, 2018 4:20 pm
Smoker wrote:Have to decide on a method for chopping the rusted out fuel tank. Still smells like old gas.
I have used water to purge tanks, but you have to watch for flash rust. A good way to purge a tank is to run a hose from the tailpipe of your car and into the tank. Let it run (around 30 minutes typically) and that should do it.
BigGuy
#282
Post
by BigGuy » Wed Feb 07, 2018 6:47 pm
silverstrom wrote:Smoker wrote:Have to decide on a method for chopping the rusted out fuel tank. Still smells like old gas.
Shake "N" Bake!
#283
Post
by Smoker » Sun Feb 11, 2018 12:06 am
Will try to cut the tank tomorrow.
Getting more titanium hardware as I go along.
Always have to buy long, then cut & thread to get the right shank length.
The removable frame downtube has shallow indents for the bolts. Don't really like the bolts sticking out, so went with super-low dome heads.
Perfect diameter and height for the indents. Not the best head for this application, but perfectly safe- just may be hard to get out if the threads lock up.
Smoker on Sun May 20, 2018 10:49 am, edited 1 time in total.
#284
Post
by Smoker » Sun Feb 11, 2018 11:44 pm
Chopped the rusted tank. Didn't blow up. Used a drill and jigsaw to avoid sparks.
Will start shaping up the lower part with the mounting points.
#285
Post
by silverstrom » Mon Feb 12, 2018 3:14 am
Looks like that tank was lined at some point, or is that something else Pete?
