My 500 YZR screamer project
ncr160
#1 Post by ncr160 » Sun Jul 06, 2014 12:08 pm
Hello, I know there are no pictures of the progres of my bike, but I am very pleased to show you the result before painting.
This bike was built between several projects. It took 10 years but what a joy to have finally running.
His first trip was made on the circuit of Nevers Magny Cours during the meeting organized by the French 500 rdlc club.
I hope that you will appreciate and with time (lot of), I will place some additional photos.
DSCF1899 m.jpg (243.97 KiB) Viewed 6844 times
After the first main jet change
https://www.youtube.com/watch?v=J609D3Q ... e=youtu.be" onclick="window.open(this.href);return false;
The dry clutch
https://www.youtube.com/watch?v=IAhXON3POZU" onclick="window.open(this.href);return false;
And the most importantly, my friends with whom everything is possible
https://vimeo.com/100021660" onclick="window.open(this.href);return false;
Ax-Racing
Re: My 500 YZR screamer project
#2 Post by Ax-Racing » Sun Jul 06, 2014 12:23 pm
screamer means that you've change sequences of sparks every 90° ?
Alex
ncr160
#3 Post by ncr160 » Sun Jul 06, 2014 12:38 pm
Yes I have with 2 tz 250 flywheel (one on each crank).
Hope to see at the French RDLC meeting next year
Ax-Racing
#4 Post by Ax-Racing » Sun Jul 06, 2014 12:50 pm
wow !!!
how about vibration ?
did you have balancer shaft installed or kept away ?
Alex
ncr160
#5 Post by ncr160 » Sun Jul 06, 2014 1:16 pm
I still running slowly the engine so I can't give you all the informations. But Thanks for your wow.
For the vibrations, as I kept away the balacer shaft, there are some vibrations. I don't know why but only during the deceleration (aroud 7 000 rpm).
I'll give you more information after the next setting ( main jet, curve ignition setting, air boxes, ... ) because I still have a lot of details to finish the project.
Ax-Racing
#6 Post by Ax-Racing » Sun Jul 06, 2014 2:07 pm
Thank you very much
i'm elucubrating similar project from some month
what ignition hardware have you installed ?
Alex
Blackshaheen
#7 Post by Blackshaheen » Sun Jul 06, 2014 2:41 pm
Fucking hell!!!!!!!!!! :shock: :shock: :shock: :shock: :shock: :shock:
Sorry.
Amazing :cool:
Details and lots of pictures please...
Congratulations! :D :D :D
ncr160
#8 Post by ncr160 » Sun Jul 06, 2014 2:58 pm
For now I run with cdi units from 250 tz 4 DP40. Next week, I'll get two fully programmable units form DEVMOTO.
I'll let my impressions in a few weeks because I'm going on holiday with my childrens.
Ronnie
#9 Post by Ronnie » Mon Jul 07, 2014 1:55 am
The ingenuity, determination and creativity on this forum never ceases to amaze me. Congratulations. C'est magnifiique! :-D
vin97
#10 Post by vin97 » Mon Jul 07, 2014 7:52 am
Awesome, the sound is amazing.
We definitely need some onboard videos, though :D
ncr160
#11 Post by ncr160 » Thu Jul 10, 2014 3:58 am
For the onboard video, I'll probably done one in October.
For the information and details :
Frame and swing from Aprilia 250 rs with some modifions for the shock absorbers from WP.
Swing finished
bras fini m.jpg (233.11 KiB) Viewed 6650 times
Modification of the swing arm for the WP absorber
bras ap ouverture m.jpg (204.52 KiB) Viewed 6650 times
ncr160
#12 Post by ncr160 » Thu Jul 10, 2014 4:01 am
TZ ingnition support for the 500 RDLC engine.
Helmers58
#13 Post by Helmers58 » Sat Jul 12, 2014 8:07 am
Very nice work! Does the taper on the standard rd500 lower crankshaft fit the taper on the tz4dp flywheel?
TS250x, TDR250, NS400R,
RGV250, Honda RS250,
610TC, RS250, GSX-R750,
R1, RSV Mile R, Bimota 500 VDUE,
1098S, ZX6RR, GSX-R1000, RG500, TZR500, S1000RR HP4
ncr160
#14 Post by ncr160 » Mon Jul 14, 2014 6:31 am
For thé cracks, I have uses 2 front one but unfortunatly you have to machined it to fit thé TZ flywheel.
Ax-Racing
#15 Post by Ax-Racing » Tue Jul 15, 2014 10:10 am
In wich way have you changed phases between the two crancks ?
you can not obtain a 90° rotation with a 31 tooth gear.....did you build a new gears ?
Alex
