I know it will not just bolt up… Here the thing maybe you can help me see the pic. This TZ pipe looks not 100% but close to the RD pipe.
http://www.jl-mxshop.com/yamaha-tzr250- ... -130-p.asp" onclick="window.open(this.href);return false;
http://www.jl-mxshop.com/yamaha-r5--rd3 ... -478-p.asp" onclick="window.open(this.href);return false;
So if the reg pipes looks 90% the same then way will the TZR 3MA pipe not fit on a reverse cyl RD.http://www.jl-mxshop.com/yamaha-tzr250- ... -215-p.asp" onclick="window.open(this.href);return false;
Here is a pic of a reverse cyl RD. Pipes looks wrong one is to long.
http://www.bikechatforums.com/viewtopic ... e+cylinder" onclick="window.open(this.href);return false;
Thank you, Steve
reverse cyl RD
Re: reverse cyl RD
For questions about your reverse cylinder project, sign up on the 2-cylinder site:
http://www.rzrd500.com/phpBB3/index.php" onclick="window.open(this.href);return false;
Not sure if the tz rear cylinder pipe could be modified to fit. Would probably be better to go with full custom pipes. Ask kenny or GPL Racing on the other website.
