Alloy Frame, Project 51X
Well gents, starting the big Alloy frame Restoration.
Re: Alloy Frame, Project 51X
Interesting to Note: These exhausts do not seem to have the restrictors fitted to the header pipe.
Just looking thru your pictures, i noticed your swingarm pivot nut was missing, i hope you took it off? Seemed early to do so. Also just thought i would note that the RZV bikes, had only 51X stamped on the engine without the rest of the serial number.
And your bike has only one 2 stroke oil resevoir where RD/RZ500s have 2.(normal for RZV)
Looks very original and untampered. Must be RZ/RD open exhaust. What does the sticker say on the CDI box on the RH side of the bike? Are you rebuilding the engine or just inspecting for now?
RZV with a single two stroke oil tank..... where other RD's have two....??????
Are you not thinking about the radiator expansion tank?
Andy (UK)
RZV500R
FRC
Faster Faster !!!
RZV500R
FRC
Faster Faster !!!
The 51x only has the one, mines the same, and its listed in the 51x parts microfiche, page 35. I wonder why?
I was just checking how much trouble I was going to have removing the swing arm bolt. The bike has a bit of corrosion over it from sitting, the bold started to move after some persuasion.
Well got a bit done inside over the rainy weekend.
Yep, you are spot on mate, only one two stroke oil tank on mine.sundaytimes wrote:The 51x only has the one, mines the same, and its listed in the 51x parts microfiche, page 35. I wonder why?
I got all of my bolts re Zinc plated, so I decided to throw in the rear sub frame as the silver paint was coming off and it was going rusty. I think its a bit bright at the moment but it will dull with age and besides its covered by the seat.
I finished overhauling the forks,cleaned them up and thew a couple of new seals into them. I will replace the oil and re- assemble. Anyone know the oil quantities for each leg?
probably here somewhere's stanky!!!! http://www.rz500.net/RZ%20500%20Pits_3.htm" onclick="window.open(this.href);return false; and http://www.rzrd500.com/500phpBB3/viewforum.php?f=21" onclick="window.open(this.href);return false;
Thanks mate, spot on!
Don't forget the RZV has different forks to the RD and RZ. Heres a copy of the page from the RZV manual. It recommends 296cc of oil. I also use 10w oil instead of the 5w which I find better.
Thanks very much for that info Steve.
Re-zinced all my fittings, in my opinion it makes the bike look half reasonable.
