Looks superb !! - well done !!
Alloy Frame, Project 51X
Re: Alloy Frame, Project 51X
Wow. That bike looks beautiful!!!
Congratulations.
Have you finalized your jetting by any chance?
If so can you post where you ended up.
Thanks.
Congratulations.
Thanks.
Ken's Garage YouTube Channel
I settled on 185MJ and the un-restricted emulsion tubes and needles, I have given it a bit of hard top end reving around the streets where I work then tried a plug chop. the plugs come out a nice brown biscuit colour running those K&N filters. I am getting a little bit of smoke on the lower rev range off the pipe.
Those standard Elephant ear air tubes would have to be the worst design I have ever laid eyes on!2smoke wrote:That looks like it will work but now you have to change the main jets.
I am going to say 250 then work down. Dont sell your elephant ears and airbox. You are going to want them again later.
The last piece of the plastics came back from the painters and has been fitted up. I cant believe how brittle the original stuff is as every piece needed some form of plastic welding!
Being 30 year old plastic with god knows how many heat cycles. i think most original plastics that have been on bikes will be a little brittle.
But excellent work!
But excellent work!
Andy (UK)
RZV500R
FRC
Faster Faster !!!
RZV500R
FRC
Faster Faster !!!
