My project (1GE)
PilotMarky
Re: My project (1GE)
#46 Post by PilotMarky » Mon Jan 19, 2015 8:15 pm
I will take a look in my bag of coil mounting hardware next time i am at hangar...
Mark
jackson.40
#47 Post by jackson.40 » Tue Jan 20, 2015 1:59 pm
The upper coil bracket mounting bolt,spring washer and flat washer are captive and bright zinc.
The rear brake hose guide bracket is bright zinc.
The plain washer is not captive, found the whole assembly how it is shown on 2 bikes coming from totally different owners ;)
Spot on :cool:
Speed Freak
#48 Post by Speed Freak » Wed Jan 21, 2015 5:20 am
Nice toes, are they also original Yamaha? :mrgreen:
What type of bolt is the upper ignition coil bracket bolt?
Acc. to the parts manual it should be the same as for the YPVS servo bracket and this is a yellow hexagon head bolt.
Maybe this bolt is also wrong in my bike?
The confusion is getting worse and worse :smt017
Is the small plain washer on your brake fluid reservoir mounting bolt captive?
If yes, there are definitely differences in production.
From which bike is it coming? 1GE or 47X?
Mine are both 1GE, (number ~1500 and ~3500)
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
jackson.40
#49 Post by jackson.40 » Wed Jan 21, 2015 5:59 am
The high cost of parts means no money left for shoes :grin:
My upper coil bracket bolt is a flat head like the bolt which holds the YPVS servo to the bracket,but it is bright zinc.
The brake fluid reservoir mounting bolt washer is not captive on my 47x bikes.
Speed Freak
#50 Post by Speed Freak » Wed Jan 21, 2015 5:03 pm
No CAD progress today...
Just playing with my new toy:
50T press :mrgreen:
Not the most expensive model but good stuff for the money.
Pressing out wheel bearings? Feels like pushing the finger into warm butter...
Wide enough for 17" wheels with tires or up to 21" rims without tire and strong enough to rebuild crankshafts.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Kalim
#51 Post by Kalim » Wed Jan 21, 2015 9:15 pm
Nice!
Speed Freak
#52 Post by Speed Freak » Thu Jan 22, 2015 6:02 pm
jackson.40 wrote: My upper coil bracket bolt is a flat head like the bolt which holds the YPVS servo to the bracket,but it is bright zinc.
That means 97301 is bright silver zinc?!
97302 is the same bolt, just yellow.
Then my YPVS bracket to frame mounting bolt is wrong (it`s yellow)...
Edit:
Sorry - it`s evening... Didn`t read "but".
Checked the YPVS servo to bracket bolts, flat hexagon head yellow on both bikes.
But no bracket to frame bolt on my second bike as the servo was in a box and not on the bike :(
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
jackson.40
#53 Post by jackson.40 » Thu Jan 22, 2015 6:58 pm
The parts list shows the wrong bolts(middle of photo) that fit the servo motor to the bracket,correct bolts are on the right of photo. The bolt on the left is correct to mount the bracket to the frame(washers are captive)
Speed Freak
#54 Post by Speed Freak » Fri Jan 23, 2015 7:23 am
Thanks for the picture.
Everything original on my bike :grin:
Do you know the correct numbers?
They made a lot of mistakes in the parts manual :smt005
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
jackson.40
#55 Post by jackson.40 » Fri Jan 23, 2015 4:53 pm
Maybe 91313-06025 but it would have the grade stamped on the head.
Speed Freak
#56 Post by Speed Freak » Fri Jan 23, 2015 6:27 pm
I need to clean up and sell some Bikes - my garage is getting too small :mrgreen:
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#57 Post by Speed Freak » Sun Jan 25, 2015 3:50 pm
jackson.40 wrote: Image
On the right side - the 2 nuts for the rear brake master cylinder...
On the picture they are silver zinc - my 2 are in bad condition, but on the contact surface where is no corrosion they are slightly yellow?!
It would make sense that they are silver, all other 90185 nuts are also silver.
Edit:
Checked my spare parts bike.
One again with a light yellow shine and the second one is clearly yellow zinc.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
jackson.40
#58 Post by jackson.40 » Sun Jan 25, 2015 4:05 pm
Yes these should be bright zinc,the nut is also used for the lower exhaust mounting bolt.(E15 12+25)
But the nuts that hold the rear footrest on are gold zinc on 47x bikes,what has your 1ge bikes got?(E15 9+22)
Speed Freak
#59 Post by Speed Freak » Sun Jan 25, 2015 4:17 pm
As written in my edit - i found a wonderful yellow one behind the rear master cylinder on my spare parts bike.
Edit2:
Sorry, too much CAD toda, I`m confused :smt003
90185-08106:
I found 6 of them, 5 have a yellow shine and yellow areas in the thread, one is clearly golden.
90185-10115 (footrest):
Has also the same yellow shine.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#60 Post by Speed Freak » Sun Oct 04, 2015 12:37 pm
Too much other work this year...
But now i have started to work on the RD500 project again.
Currently i`m learning Microsoft Access to build up a database - Excel is not made for what i want.
If the Database works i can collect every info to the parts and even more important - find it again very easy :mrgreen:
The next step will be new zinc on all parts, therefor i need the database to find the correct part number to each bolt/bracket again.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
