Even though the wheel is a 6" wheel and the race style 18/67-17 Michelin is mounted, the assembly easily sits in the center of the swingarm with good clearance all round. I will not attempt to mount a 190 section rear tyre - no point really, the street style 180-55/17 should be ok, although I am sure the 6" rim will push the side walls out slightly reducing rolling diameter ever so slightly.RGVSTEVE wrote:Paul,
How close is the rear wheel to fitting and being centered in the swingarm.
Steve - the mission, should you accept it, is to come up with a way to get a rear brake rotor correctly offset for the caliper and a sprocket correctly sized and aligned.
The rotor mounting holes are 125mm center to center in a square layout. Sprocket bolts appear to be 98mm center to center vs the 100mm that is on the Suzuki wheel.
This post will not self-destruct after you read it ..
**EDIT**
Mystery solved - the wheels are for 92 to 94 CBR900RR.
Here is a photo of the only other set I can find - a bike featured in 2002 Sport Rider. I managed to get hold of the owner of the VTR, he confirmed these to be Marchesini, Honda CBR application.
