Clevis Pin for Rear Fuel Tank Bracket
Re: Clevis Pin for Rear Fuel Tank Bracket
#16 Post by Smoker » Mon Mar 12, 2018 12:55 pm
phildu31 wrote:Ok, that's a real deal.
Mind the galvanic corrosion with other parts in metal.
Always a good reminder.
I have LM508, which I've read is very good.
On much of the titanium hardware, I'll he using be using Loctite Blue as an antiseize compound. Loctite makes antiseize compounds, but Blue will seal against air and moisture, preventing galvanic corrosion as well as locking the threads.
phildu31
#17 Post by phildu31 » Mon Mar 12, 2018 1:43 pm
I think this is more for protection against corrosion from the outside.
Galvanic corrosion is an electrical phenomenom that occurs for example between titanium bolts and calipers by welding the two parts together.
Can be a little annoying...
