Are these still available from Yamaha?
Or does anyone have a useable one?
I'm going to have to modify mine a fair bit for the injection etc, so I dont mind if anyone has one that needs some work.
Wiring Loom
hybrid,
You are going to have to make one hell of a wiring harness for the fuel injection anyway. And you are going to use Borut's CDI. So you might as well make what little is left for the lights and combine it all into one harness. You won't be running the original clocks, will you?
Just my two cents.
Just my two cents.
Fuel Injected RZ350
