Page 4 of 4
Re: RZ 500 electrical problem
Posted: Sun Aug 05, 2018 3:20 pm
by vma500
Did u find the problem Ron?
Posted: Tue Sep 04, 2018 6:57 pm
by not the woose
Hi Ron, if you haven't fixed the problem yet try a simple test.
When the engine stops remove the fuel tank cap, turn the fuel tap to prime then try starting.
The breather in the cap is very small so can block easily.
Good luck.
Posted: Wed Sep 05, 2018 6:27 am
by Linx
With this symptom my money would normally be in the ignition coils. It's just a bit strange it's effecting all 4 cylinders at the same time and not just 2. I'd still try changing one or both ignition coils.
