manual switch to operate the cooling fan
william2rcc
#1 Post by william2rcc » Sat Mar 24, 2018 11:24 pm
I try to use a manual switch to operate the cooling fan, i.e the "thermo switch" still function, although I don't turn on the switch, but I can not find the "thermo switch", in the circuit show the cooling fan motor negative is always ground, the cooling fan positive is through "thermo switch" to 12v+, please help me to do it, thank you!
P.S I already done on my NS400R add a manual switch to operate the cooling fan.
Speed Freak
Re: manual switch to operate the cooling fan
#2 Post by Speed Freak » Sun Mar 25, 2018 5:30 am
You only need to "bypass" the switch with a second mechanical switch.
If one of both is closed the fan will be on.
You can simply make an intermediate adapter between the thermo switch and the original connector.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
phildu31
#3 Post by phildu31 » Sun Mar 25, 2018 7:26 am
Thermo switch is near the thermostat under the fuel tank.
