Hallo,
I would like to know what is the function of the Reed Switch (nr.37 on the drawing)?
Can i take it away because i will install a koso RX2N.
Thanks for the tips,
Walter
reed switch RD500
Re: reed switch RD500
It is inside the speedometer and is part of the self cancelling turn signals, it provides the distance count to the controller. If you don't want or need the self cancelling feature you don't need it.
Thanks,
Do you know if it is nescary to use the red/yellow cable ho is connected between the cancelling unit nr.30 and the turn switch nr.25?
Because i will use Aprilia handels en they are missing one contact.
Thanks Walter
Thanks Walter
You can unplug and remove the self cancel unit and the signals will work fine.
