shock knuckle removal
I'm doing total restoration on a rz 500.Got down to shock knuckle and cannot figure out how to remove bolt that holds shock knuckle to frame. thanks for your help.
- Speed Freak
Re: shock knuckle removal
Simply turn out the bolt thru the hole in the frame
Never turn the nut side of this connection, use the bolt side (allen key) and use the small hexagon on the other side only if the nut starts turning (just for holding it).
If you apply torque to the small hexagon it will snap off.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
thanks speed freak, worked just like you said.!!!
