Front Fork bushes success!!
Well as some of you may know the front fork bushes on the rd500 are not a seperate item from the stanchion additionally they are no longer available aswell!!
I posted on here months ago and was advised to try Wemoto.com as they stock quite a few bushes, after searching their website it appears that they do not stock the sizes needed for the rd500, so did a lot of searching on web and eventually found a company here in the UK called K-tech and ordered some bushes. Fitted them today and they are perfect fitment, so am a very happy bunny now!
Heres the part numbers for ya all
Top guide bushes are listed as Part no GBS-003 Showa 37mm guide bushes 37x12x2.00
Bottom sliders bushes are listed as Part No SBS-003 Showa 37mm guide bushes 37x 20
AND they only cost £26 odd inc delivery and took 2 days to arrive, excellent service!!
cheers Colin
cheers Colin
- Marsupilami
Re: Front Fork bushes success!!
Not that I'm currently in need of them, but thank you very much for the info!
Excellent detective work !
Many thanks.
Many thanks.
I bought mine here http://www.ridejbi.com/fork-inner-bushing/" onclick="window.open(this.href);return false;
The slides are identical to stock.
Great job, Thanks for sharing the info...
Ordered mine directly from K Tech in the U.K. They arrived next day!
Gettin' kinda squirrely!
- jackson.40
You can get them from Ebay UK as well.....................
http://www.ebay.co.uk/itm/Set-of-4-inne ... Swd0BV1zXy" onclick="window.open(this.href);return false;
Steve
Steve
- Speed Freak
Measured the K-Tech bushes yesterday.
Height: 19,7-19,75mm (K-Tech), 19,8-19,85mm (Yamaha) - the width of the pocket in the fork leg is 20mm.
Diameter with closed gap: difference smaller than diameter deviation around the part (+-0,1mm)
Thickness: 1mm (K-Tech), 0,9-0,95mm (Yamaha, old worn bushes)
Haven`t checked the diameter in mounted conditin at the moment, but from the measurements above there will not be much difference, only a slightly bigger diameter because of wear.
Result:
They are 99,9% the same but I think not from the original supplier (for Kayaba) because they are golden on the inner side and the Yamaha parts are black.
Maybe I can get some original Kayaba parts...
Result:
Sometimes I think life is too short to worry about 0.1mm!
- Speed Freak
I don`t worry about it, the message should be that they will work.
This difference is maybe smaller than the production tolerance of such parts.
But if I get the parts from the original supplier... why not?
Good man. Could you let us know part numbers if you do?
I fitted these when I rebuilt my forks - all good so far
cheers Andy
cheers Andy
RD500
TZR250 2MA
TZR250 3MA
TDR250
YZF600R
DT125RE
XS750E
DTR125
FZ1
TZR250 2MA
TZR250 3MA
TDR250
YZF600R
DT125RE
XS750E
DTR125
FZ1
