bellypan stone bracket
General forum on frames, brakes, suspension, wheels and tires
shergar
Re: bellypan stone bracket
#16 Post by shergar » Wed May 16, 2018 10:16 am
Would you have a picture of the correct bolt John just hard to make out how it looks and works mate , ta
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
silverstrom
#17 Post by silverstrom » Wed May 16, 2018 11:54 am
shergar wrote:Would you have a picture of the correct bolt John just hard to make out how it looks and works mate , ta
You'll find 2 good views here https://www.cmsnl.com/yamaha-rd500lc-19 ... vxF9OSG-Uk" onclick="window.open(this.href);return false;
1990 TDR250 Pre-Production # 000001
shergar
#18 Post by shergar » Wed May 16, 2018 4:54 pm
if you screw the correct bolt down tight how dose it swivel ? ta
my bikes.
CBX 1000 , RD 500 .
shergar
#19 Post by shergar » Wed May 16, 2018 5:34 pm
the bolt to buy is 1euro and 19.50euro to post total 25.22 inc vat what a joke , there robbers that crowd , p
my bikes.
CBX 1000 , RD 500 .
silverstrom
#20 Post by silverstrom » Wed May 16, 2018 6:37 pm
Loosen the screw, swivel the bracket. Swivel the bracket, tighten the screw.
If Yamaha doesn't have the screw available do what everyone else does: go through your hardware box and find any Yamaha screw that is the correct colour and size and then use it. No one will know and no one will care. It's a screw ;-)
shergar
#21 Post by shergar » Wed May 16, 2018 6:51 pm
no its just that when i seen the part on youtube i was on the understanding that it was spring loaded somehow at the screw which ment you didnt have to loosen each fill , p
my bikes.
CBX 1000 , RD 500 .
podman
#22 Post by podman » Thu May 17, 2018 11:36 am
Its 66 pence from Fowlers...post will sting you a bit more so see what else you may need , there's always something!
https://www.fowlersparts.co.uk/parts/40 ... 9/oil-tank" onclick="window.open(this.href);return false;
silverstrom
#23 Post by silverstrom » Thu May 17, 2018 12:16 pm
podman wrote:Its 66 pence from Fowlers...
Which typically means Yamaha has it available.
rd84
#24 Post by rd84 » Thu May 17, 2018 5:32 pm
shergar wrote:no its just that when i seen the part on youtube i was on the understanding that it was spring loaded somehow at the screw which ment you didnt have to loosen each fill , p
The screw has a special slot machined into it so you can loosen or tighten it with either a screwdriver or a coin.
