Hi Guys
Stripped off the the front end of the RZV to replace the fork seals. I had to remove the Anti Dive units. There are 4 "O" rings sealing the oil from the fork leg. Are these standard "O" rings or Yamaha specific? If the latter where can I get them from as Yambits and the like in the UK don't appear to stock them.
Marty
Anti dive valve "O" rings
- Attachments
- All stripped ready for super clean and refit
- Copy of 2015-04-08 16.33.38.jpg (83.71 KiB) Viewed 1850 times
- jackson.40
Re: Anti dive valve "O" rings
Still available from Yamaha,part number 22N2314700.
Steve
Steve
- Contact:
I got some from Partzilla.com they were like $7 a piece though! Cheaper to buy a full o-ring kit from Home Depot!
Mark
- Speed Freak
According to my excel list they should be:
2,4x11.8 JIS B 2401 P
11,8mm inner diameter
2,4mm diameter of the rubber
Standard: JIS B 2401 P (Japanese Industrial Standard)
Measured from a new original part and measurement compared to all Japanese O-Ring standards i have found (JIS and JASO).
They just seal the fork oil which isn't under high pressure or hot so good quality "O" rings of the same size and section will be fine. I just replaced mine form a kit I have however, any good bearing supplies store will have them for a small cost.
Love classic 2 Strokes
Regards,
T Newts
1984 Yamaha RZ500 L
1981 Husky WR430
1974 Yamaha DT175 B
1995 Suzuki RGV250 T
1979 Suzuki GS850 GN
2000 Husaberg FE600E
2004 Aprilia RSV1000r
1981 Yamaha IT250H
Regards,
T Newts
1984 Yamaha RZ500 L
1981 Husky WR430
1974 Yamaha DT175 B
1981 Yamaha IT250H
Thank you Gents. Bought the genuine from Yamaha. Thanks Steve for part No:
