Splitting the cases
Splitting the cases
This is for any and all who have split the cases of an RZ/RD/RZV500.....
The two bolts under the lower edge of the front cylinders.
I have tried to get them loose, but they seem to want to stay where they have been living for the past 35 years.
I have tried an impact driver with no luck, and I'm worried I will round them out with much more force.
They are pretty long, so I'm not sure how much heat it would need to get all they way to the threads.
Possible worse case is either weld a nut to the top to get a better bite, or cut across the heads to get a big flat head screwdriver bit onto them....?
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Re: Splitting the cases
I'd soak it in PlusGas for a couple of days and try the impact driver again. Make sure you've got a good fitting hex bit. I've had good success after hammering in a slightly larger torx bit for extra bite too.
Sent from my HTC Desire 530 using Tapatalk
Current Bikes
Past Bikes Include
Past Bikes Include
Drill the head off, split the case and then weld a nut to it when the tension on the threads has relaxed
Ive opened a lot of these cases and I use a large round punch, Place it perfectly flat on the head of the bolt and give it a good crack of a hammer, Then put your Allen wrench into it and loosen away. Never had one fail yet....
If it does fail, I would drill the head off, separate the cases and grab it with a good square nosed vice grips and loosen it...
It's going to be very hard to get at with a grinder without damaging the case [emoji848].
Current Bikes
Past Bikes Include
Past Bikes Include
+1 for drilling the heads off. I did this last week. Straight-forward.
Once the cases were split, I could unscrew the shanks of the bolts with my fingers!
I will not use button heads when re-building, as standard cap-heads do not protrude above the base gasket surface—-just.
Why would you even try using a grinder in there, Drill the head off, Not grind it.....
God knows [emoji1].
Current Bikes
Past Bikes Include
Past Bikes Include
I mentioned cutting a slot, not grinding head off....(done successfully on previous issue bolts)
Question was asked before I made any non reversible attempt, to find the best route.
I have too much money in this to F¥€£ it up.
Thanks for the ideas
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
- Speed Freak
I'm using the torx method for such bolts. Had some trouble with one of this bolts (2 cases) but an impact wrench solved the problem.
Impact screwdrivers are not right for this type of bolts. They are good for cross heads where the rotation leads to an axial force which pushes the screwdriver out of the head.
This is not the case with hexagon heads.
Only material of bolt and tool and the fitment are limiting the torque which can be applied.
Try to get only torque into the bolt, no bending forces. Use a T-handle instead of a ratchet or a (not too strong) impact wrench.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Split....
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
