Thanks - I’m going to take your advice on that - I really am sick of ethanol fuel problems.
Checking Fuel Level in carbs
Re: Checking Fuel Level in carbs
I started the bike today and it runs really nicely on all 4 cylinders- it needed choke in the cold conditions so it’s not running rich - sadly it started raining before I could check the fuel levels with the engine running - I’ll try again tomorrow.
HI Paul, where can i buy replacement of the fuel tap OR and diaphram ? Have bought some on the bay but they do not fit and both my RDs tap leak...
Many tks yrs help
Best
Gianni
Many tks yrs help
Best
Gianni
Hi Gianni,
The Fuel Taps are still available from Yamaha - I use Fowlers of Bristol, UK - they will despatch internationally - there are fuel taps on ebay but check the part number is correct....
https://www.fowlersparts.co.uk/parts/40 ... /fuel-tank
I would recommend the Viton diaphragm and seals even with a new tap. You can get these from NRP in the UK...
http://www.nrp-carbs.co.uk/
Viton Fuel Tap Seals and Diaphragm...
http://www.nrp-carbs.co.uk/shop/index.p ... ct_id=3439
Viton Float valve...
http://www.nrp-carbs.co.uk/shop/index.p ... ct_id=4121
Many Tks Paul. Do appreciate.
Best
Gianni
Best
Gianni
