Carb set up
PaulGreen
Carb set up
#1 Post by PaulGreen » Sun Dec 02, 2018 4:44 pm
So, I wondered into the garage and stubbed my toe on a dust sheet. When I looked under the sheet I remembered that I was the proud owner (of 25 years) of an Rd500 that I'm 90% through restoring. Looking at my thread on here I see it's been 6 years since I did anything meaningful to the bike.
When I abandoned the project all that time ago I was having trouble with the carbs. I seem to remember that there was a walk through, hand holding, set your carbs up properly thread on here somewhere but I can't find it?
Carbs are off the bike and I built a jig/stand to hold them square on the bench, but I'm not sure where to go from here.
Any help/pointers greatly appreciated.
Thanks,
Paul.
lost1750GTV
Re: Carb set up
#2 Post by lost1750GTV » Mon Dec 03, 2018 10:05 am
"6 years"
"trouble with carbs"
eeghad - I've gone months since my last inhaling fuel fumes foray, I guess I better get back to solving instead of avoiding ...
PaulGreen
Re: Carb set up
#3 Post by PaulGreen » Fri Dec 07, 2018 3:26 pm
Could somebody confirm something for me please.........
I've got my carbs mounted on the bench with a small header of fuel attached.
Before I mounted the carbs I set the float height as per the manual.
Now, using the hose on the drain valve method is showing that the fuel level is too high, it's roughly flush with the gasket face across all 4 carbs.
Am I correct in thinking that the critical measure is the actual fuel level? So rather than dismount the carbs, and measure each float individually I can tweak the tang with everything in situ?
Thanks.
Paul.
phildu31
Re: Carb set up
#4 Post by phildu31 » Fri Dec 07, 2018 4:52 pm
What value did you use for the float level ? 21mm or 24mm ?
It should be 24mm.
But you're right, the critical measure is the fuel level to confirm.
It should be 3,5mm +/- 1mm.
PaulGreen
Re: Carb set up
#5 Post by PaulGreen » Fri Dec 07, 2018 5:11 pm
I used 24mm.
Is the 3.5mm measured from the gasket face?
Thanks,
Paul.
rd84
Re: Carb set up
#6 Post by rd84 » Sat Dec 08, 2018 7:15 am
Hi Paul,
It’s from the top of the float bowl casting where it joins the bottom of the carb body.
If you haven’t got the manual it’s well worth getting - there is quite a bit about setting up the carbs in it - the first figures for float height are wrong - the correct values are in the appendix - you often see these manuals on eBay - copies are around £20 ($25) and originals around £80 ($100)
PaulGreen
Re: Carb set up
#7 Post by PaulGreen » Sat Dec 08, 2018 4:10 pm
Thanks for clarifying.
I do have a manual - I think it hails from joining the owners club back in the day? It's just that I was aware of some confusion on this topic.
Thanks,
Paul.
