Torquing the head bolts
When torquing the head bolts I usually do a heat cycle and re-torque them. However I notice that the centre nuts with the copper washers continue to rotate slightly when checking the torque no matter how many time I recheck. I assume that it's because the copper washers compress slightly further each time. Has anyone else noticed this. If so what do you do; keep tightening?
Re: Torquing the head bolts
In my experience the copper washers don't turn much. I assume you did use new copper washers. Torque until the wrench clicks. If the wrench doesn't click at the required torque be careful you aren't turning the stud.
Hi silverstrom
Yes I use new washers each time.
It's not that the washers are turning but rather they compress. If I torque them to the recommended value and leave them for a while when I re-torque them the nuts move slightly before the wrench clicks again. It doesn't happen with the nuts with the steel washers but happens with the 4 dome nuts with the copper washers. Just wondering if anyone else has experienced this?
