Hi,
Can anyone tell me what gauge wire I need to replace the strangely named "47X-16385-00 RING, clutch, boss"
Also is stainless wire ok or must it be an high tensile wire ?
Thanks.
47X-16385-00 RING, clutch, boss - Wire Gauge ??
Re: 47X-16385-00 RING, clutch, boss - Wire Gauge ??
I usually leave it out and replace the half plate with a full plate, Any reason why you want to refit it..
Hi,tacky1 wrote:I usually leave it out and replace the half plate with a full plate, Any reason why you want to refit it..
I suppose not knowing any better I would be nervous of doing the job non-standard - I don't even know why that plate is different and why it is held in place by the wire ?
I guess you've ran without this plate and wire with no problems ?
Thanks.
The back plate is there so the 1st friction doesn't ride on the aluminum on the hub.
Best I can recall the wire is the same as the R1 wire which can be ordered unlike the RZ wire. PN: 2H7-16385-00-00
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Thanks very much Bill
