Hi
Going to tinker in the shed over winter and fit a pair of carb heat shields i won on auction.
Is it a fiddly job, and or do i even need them, run this year without them and did not seem to get
any more problems then usual
Tips or hints welcome
Dave
Carb heat shields
Carb heat shields
1984 RZV500R
1985 FZ750 FN
1986 VF500 F2
2016 BMW S1000XR ( i need speed/brakes/handling
1985 FZ750 FN
1986 VF500 F2
Re: Carb heat shields
I don't think it's fiddly, i have no problems at all installing them. Clamps must be free, a little 2 stroke oil on the intake rubbers: Et voila!
Take careful note of the exact routing of the fuel pipes or the shields can be difficult to push back into place - especially the left one - if they do prove difficult check that you're not trapping a fuel line - You can clamp the fuel lines near the tank rather than having to drain the tank - memory says the right side fuel pipe goes through the shield the left one goes over the shield through a notch - could be wrong - I've done this job 20 times in the life of the bike so it must be old age stopping me remembering !
Other than the above it's quite an easy task.
Have fun !
Have fun !
Cheers Guys
Tanks empty so should make this easier, i will see if there's a pipe run diagram in the manual.
Merry Christmas
Dave UK
Merry Christmas
Dave UK
1984 RZV500R
1985 FZ750 FN
1986 VF500 F2
1985 FZ750 FN
1986 VF500 F2
