Hi All,
Anyone got some photos of the correct way to route the fuel lines from the fuel petcock to the carbs. Right side is pretty straight forward its the left side I'm finding a bit tricky. i have the lines that came off and a good idea where each bit is meant to go but no matter which way i configure, doesn't seem to quite fit right without squeezing or almost kinking something.
Br grateful for any help and particularly for a nice clear phot showing how it should be done.
Regards
B
Fuel line Routing
Re: Fuel line Routing
Hi All,
Found a thread with some pics I needed so sorted for now!
Regards
B
Regards
B
Any chance of providing the link for the thread with pictures showing the proper fuel line routing? Thanks!
Hi,
Haven't been on for a while and did this a little while ago. I found the info by using the search function on this forum and then going through the threads, if I can find it I will get back and post it,
Regards
B
Regards
B
Here is son=me info i found that might help;
http://www.rzrd500.com/500phpBB3/viewto ... ing#p60096" onclick="window.open(this.href);return false;
Regards
B
Regards
B
Thanks!!
