Engine noisy with rattle at tickover
MartyB
#1 Post by MartyB » Sun Nov 11, 2018 3:34 pm
I recently bought 1984 (early model) RD500LC. It is a one owner bike in lovely condition and rides well, but at tickover it is quite noisy/rattle compared to other 2-strokes I own. I have checked videos of other RD500s on YouTube and many sound the same as mine.
Is it quite normal for these bikes to be noisy?
Brad Winchester
Re: Engine noisy with rattle at tickover
#2 Post by Brad Winchester » Sun Nov 11, 2018 5:25 pm
Yes mine is also noisy. Pulled clutch apart all seemed OK. My bike is the only one I have heard running.
RZ500
ZXR900
FZ750x2
FZR250x2
ZXR250
GSX250
GPX250
Boulevard
KDX200 X 2
KX125
CR125
RMX250 X 2
KX80 X 2
YZ80
Linx
#3 Post by Linx » Sun Nov 11, 2018 5:28 pm
Seems to be normal. I'm not sure why. My engine is noisy at idle too.
:smt006 Current Bikes
Past Bikes Include
#4 Post by silverstrom » Sun Nov 11, 2018 5:28 pm
They are noisy. You may find the noise lessens after the engine is fully warm. Ear plugs solve the problem.
If you have forged pistons that can contribute to a rattle until they reach operating temperature.
tacky1
#5 Post by tacky1 » Sun Nov 11, 2018 9:50 pm
Mine all rattle, Balancing the carbs make them sound better, Use an air flow mete to set them rather than the OEM marks on the carbs,
Something like this https://www.ebay.com/i/173355150137?chn=ps" onclick="window.open(this.href);return false;
MartyB
#6 Post by MartyB » Mon Nov 12, 2018 6:34 pm
Thank you Sir. I have ordered a flow meter as you suggest. Will let you know how I get on, however reading some of the other post it would appear that balancing the carbs makes quite some difference.
kpke
#7 Post by kpke » Tue Nov 13, 2018 12:14 pm
It made a unbelievable huge difference on mine using that tool.
Good luck.
Linx
#8 Post by Linx » Tue Nov 13, 2018 12:55 pm
Mine is definitely quieter with the clutch pulled in. Is this normal? Or likely to be clutch or gearbox bearings?
Past Bikes Include
steveho
#9 Post by steveho » Tue Nov 13, 2018 5:05 pm
Most (if not all) of my Yamaha 2-strokes are quieter when ticking over, when the clutch lever is pulled. Some more than others. I think this is normal to a certain degree.
Not sure of the mechanism though...
Maybe pulling the lever stops the plates rattling in the basket and hub grooves, especially when worn, or maybe pre-loads sloppy cush-drive rubbers....? Anyone know?
Brad Winchester
#10 Post by Brad Winchester » Tue Nov 13, 2018 6:03 pm
The rattle on my bike does sound quieter with the clutch pulled in. Going to try carb balancing.
RZ500
ZXR900
FZ750x2
FZR250x2
ZXR250
GSX250
GPX250
Boulevard
KDX200 X 2
KX125
CR125
RMX250 X 2
KX80 X 2
YZ80
ns86
#11 Post by ns86 » Wed Nov 14, 2018 7:34 pm
From the moment I heard the first RZ500 fire up when they first arrived, I found it a gnarly sounding engine. I always assumed it was the crank/balancer gear design. Similar to the off throttle harmonic buzz/whine on all but the S model. It is certainly a unique sounding engine and always has been.
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
MartyB
#12 Post by MartyB » Sat Nov 17, 2018 3:06 pm
Hi Tacky1, synced the carbs today with the flowmeter. Cant say the engine is significantly quieter when ticking over, but runs really well and definately worth to do.
Also good comment from ns86, I had wondered if the wine as I close the throttle at higher revs was normal...clearly it is.
