replacement carb=new guy screw up
yamahoper
#1 Post by yamahoper » Sun Feb 19, 2017 7:59 pm
My bike finally showed up last night ,an ebay purchase. Add said carbs need rebuild. So I started in on Left side #1 and #2 . No problems on #2 , Number #1 the pilot jet slot was completely gone. I u tubed it and saw a guy drill out the jet, tap in a small square file and get it out that way. Well my file broke off inside then I tried to drill it again and broke that off then tried to hammer a new slot with a sharpened slot screwdriver no luck. Any Ideas out there or #1 carb for sale ? Thanks for any solutions
yamahoper
Re: replacement carb=new guy screw up
#2 Post by yamahoper » Sun Feb 19, 2017 8:01 pm
The bike is 1984 rz500rn from canada
#3 Post by silverstrom » Sun Feb 19, 2017 8:24 pm
PM me.
John
yamahoper
#4 Post by yamahoper » Sun Feb 19, 2017 10:42 pm
tried to pm silverstrom 3 times twice from my control panel once from the pm icon on this page. I don't think I'm doing it right
tacky1
#5 Post by tacky1 » Mon Feb 20, 2017 12:26 am
Check your sent or outbox in your messages. He will see you replied here also and PM You
#6 Post by silverstrom » Mon Feb 20, 2017 12:52 am
It's ok. We have it sorted out :smt023
Speed Freak
#7 Post by Speed Freak » Mon Feb 20, 2017 4:09 am
And for next time, don`t use a file.
A good quality Torx is not that brittle.
And use the biggest torx which is possible.
yamahoper
#8 Post by yamahoper » Tue Feb 21, 2017 9:58 am
Thanks Speed Freak very good solution I will remember that one!
vdrive
#9 Post by vdrive » Tue Feb 28, 2017 12:21 am
did you get a chance to test for crankcase seals .
yamahoper
#10 Post by yamahoper » Sun Mar 05, 2017 1:08 pm
I have not checked any of the seals. I don't even know where to start with them. The bike does idle fine and has decent power. So I'm hoping they are all good. Any suggestions?
yamahoper
#11 Post by yamahoper » Sun Mar 05, 2017 1:13 pm
I'm thinking the seals should have its own thread. So back to my carburetor issues.
yamahoper
#12 Post by yamahoper » Sun Mar 05, 2017 2:15 pm
So The right side carbs didn't overflow at first. I installed the left carbs from Canada with new needles and seats that I bench tested the fuel level on. Everything seemed good, bike started first kick took her for a short ride then The right carbs started overflowing so I pulled them and put new needles and seats in them. Then the lefts started overflowing again so much the fuel was dripping out of the stock air box. Next day opened the drains and closed them... just an occasional drip. Took her for a spin hoping somehow the drips would just go away. They seem to all drip a little left and right when parked, not coming out of the air box but still dripping.
The left fairing was very damaged by the previous owner from fuel leaks melted , warped , and crash damage. No lower mounting tabs all broken off, but I don't know if that's from the crash or fuel damage? The fairing was so distorted the white lines in the paint don't line up with the lower fairing. The fuel tank looks good inside I flushed it several times installed all new clear fuel lines and an in line filter. I'm wondering if the floats can go bad? Also if the drain screws can be leaking ? Not sure what to do next?
#13 Post by silverstrom » Sun Mar 05, 2017 2:40 pm
Check your float level. If it's too high it will drip fuel out of the drain lines forever because fuel is above the overflow pipe in the bowl. Should be 24 +/- 1 mm.
If the bike is dripping when parked check your fuel tap/petcock. There should be no fuel passage when the engine is off. None.
yamahoper
#14 Post by yamahoper » Sun Mar 05, 2017 7:54 pm
thanks for the check it again silverstrom ! #1 fuel level was real high and #2 was a little high. still getting a drip from #2 so ill pull them again and recheck. I was actually using the running test with the drain tube pointing upwards but on the bench not running so I'll use the ruler method and let you know the results.
BigGuy
#15 Post by BigGuy » Mon Mar 06, 2017 1:10 am
Hi, from my experience this is pretty common. First thing after verifying that the fuel levels are correct is the needle valves. The bore of the needle float valve seat must be clean, like the thing after clean, lol. Below is a link to a video of a guy cleaning these valve seats on a different carb but I'm sure you will get the idea. I have done something similar, I cut some Q tips in half, put them in the chuck of my little drill press. I then put a bit of metal polish on the Q tip, run the drill pretty fast, simply hold the valve insert in your hands and polished the bore a bit. After polishing clean all residual polish compound off and reinstall the valve seat in the carb body.
https://www.google.ca/url?sa=t&source=w ... nGP_UlkifA" onclick="window.open(this.href);return false;
Silverstorm is correct about the petcock, thats worth a look also.
Hope it helps, good luck!
Shake "N" Bake!
