clutch cover removal
What is the sequence of disassembly for removing the clutch cover?
Does the water pump stay on?
The manual says to remove the bolts, not very helpful. If I just remove all the screws for the cover will it pull off?
A search here I could not find anything.
Seems like the the hard water pipe needs to be removed but I am hoping not.
Ken
Ken's Garage YouTube Channel
Re: clutch cover removal
For other rookies...
Hard water pipe screws must be removed.
Remove water pump with water pipe attached.
Remove last side cover screw underneath water pump.
