hi all
Was just wondering the best position for power valves when not running
With power valve controller?
Fletch
Position of power valves?
allways look on the bright side of life
LMAO
LMAO
Re: Position of power valves?
Fletch,500.FLETCH wrote:hi all
Fletch
Are you intending to lock them from rotating and your wanting to know where to lock them?
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
No not lock them my control box is off for repair just want to ride it
And want to know best position for riding
If this make sense?
Fletch
If this make sense?
Fletch
LMAO
LMAO
The owner before me on my 350 locked them half way and the valves was deformed, probably from the heat?? I would leave them fully open. I have tried it on my 500 and it becomes VERY bad in low/mid range the 350 is much more enjoyable with locked valve. / Stinke
2 x rd 500 -84
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
The best of swedish metal: https://youtu.be/gkBt7yLXyDk" onclick="window.open(this.href);return false;
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
- Speed Freak
Would also lock them fully open.
Not very nice to ride it, but if it`s just for a short time...
Had the same situation with my Honda NSR125 - 2 years i didn`t check the valves (different construction) - when i removed the exaust i saw that one of the 2 flaps is damaged and closed all the time. Removed both flaps and was a little bit supprised by the power of this small bike but just from 8-10000rpm
Below that it was just horrible. nearly no power below 5000rpm (nice at traffic lights, either you stall the engine or it sounds like at a race start).
Cheers guy's have moved them to fully open
many thanks
many thanks
LMAO
LMAO
