hi all just a quick one on the engine oil pump assy
from drain plug side i have put it together as per manual
but i have alot of play ( ie side to side ) from clutch side if i push it in towards the oil drain side it locks up when you rotate the gear ?
many thanks
Fletch
engine oil pump
engine oil pump
allways look on the bright side of life
LMAO
LMAO
