Can the supply line fitting on the oil pump be turned without any surprises?
Is it threaded, pressed in or ???
I would like turn this fitting about 45 degrees.
Thanks.
oil pump inlet fitting
Ken's Garage YouTube Channel
Re: oil pump inlet fitting
I have a couple pumps on the shelf. I will take a good look at them today and report back.
OK so its 100% pressed but will turn. Just turn it in the direction you need it. Watch the hose routing won't interfere with the arm above it though. I will post a picture tonight.
Thanks 2smoke. I was able to get it to turn.
