oil pump inlet fitting
kpke
#1 Post by kpke » Sat Feb 28, 2015 2:48 pm
Can the supply line fitting on the oil pump be turned without any surprises?
Is it threaded, pressed in or ???
I would like turn this fitting about 45 degrees.
Thanks.
2smoke
Re: oil pump inlet fitting
#2 Post by 2smoke » Sun Mar 01, 2015 3:22 pm
I have a couple pumps on the shelf. I will take a good look at them today and report back.
2smoke
#3 Post by 2smoke » Sun Mar 01, 2015 5:03 pm
OK so its 100% pressed but will turn. Just turn it in the direction you need it. Watch the hose routing won't interfere with the arm above it though. I will post a picture tonight.
kpke
#4 Post by kpke » Mon Mar 02, 2015 2:14 am
Thanks 2smoke. I was able to get it to turn. :smt023
