crank bearing split
crank bearing split
can some please explain how this happed
many thanks
fletch
allways look on the bright side of life
LMAO
LMAO
Re: crank bearing split
Never seen that before!
It may have cracked from the dowel hole.
Has it been rebuilt, what brand bearings are they?
If the dowel was under side force (pushing against the cases because it didn't fit in the groove) this might be the result.
What does the matching notch in the case look like?
all looks good only split engine to-do crank seals
and found this have two marks inside the crank case but nothing to write home about
Fletch
Fletch
LMAO
LMAO
How many miles/kms on the crank??
According to Stan Stephens in Classic Motorcycle Mechanics should this happen after 23000 miles / 36800 km
/ Stinke
/ Stinke
2 x rd 500 -84
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
The best of swedish metal: https://youtu.be/gkBt7yLXyDk" onclick="window.open(this.href);return false;
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
Double check but I think the bearing that Stan speaks of failing is an outer bearing (93306-20565 - upper crank/right side) that has a circlip groove, which is the reason for failure due to the location of the groove.
The failure in question here is an inner bearing, which does not have a circlip groove. I'd love to hear what did cause this catastrophic failure - sure looks ugly. Maybe Bill or Rick can share if they have seen anything like this...?
Yep you are right, I was so happy that I found the article I didn't read it properly. But I think both type of bearings seems fragile.
/ Stinke
/ Stinke
2 x rd 500 -84
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
Rd 350 ypvs -84
Rd 250 -74
Kh400, t20
maybe the crankcase lube holes blocked ? and the dowel pin did do the rest
mine did over 50000 kms , but have never seen this before
my bikes :RD500 2X ,RD 350 F2 , RD 350 31K,RD350 4LO,RG500,RG250 WW,RGV250,TZR250 3MA,TZR250 3XV,NS400r,NSr250 mc21,KR1250S,
she's done 30000kmssmokamoto wrote:How many miles/kms on the crank??
all crankcase lube holes clear
koyo bearings are fitted I did not rebuild the engine
many thanks to all that replied
Fletch
LMAO
LMAO
Hmm, maybe i should think twice about my plan to not replace the crankshaft bearings in my 40000km RD...
Looks to me like a manufacturing fault, i have seen this on a number of bearings which have roll pins, dowels, grub screws etc set into the race. If the bearing has the slightest machining defect in this area known as a stress raiser the bearing will fail over time. Just to add, if you send the bearing to a metallurgist or company specialising in metallurgy they will tell you exactly where and why the bearing failed.
If only there was more free time.
