500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Mon Aug 20, 2018 5:53 am
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: rs500v2 hybrid
PostPosted: Sun Jan 10, 2016 10:54 pm
put pipes on and the old mk1 tank to see how it sat
ive got a nice mk2 black mint tank to go one when its done
top exhaust will need to be modded so it doesnt point up like that the mk1 tail piece wont go with it like that
it will point straight out instead
PostPosted: Sun Jan 10, 2016 11:00 pm
the inlet manifold i was going to use was a few injection parts that people use to change over to carbs from injection
a bit of a mess and restricive frp make one but its nearly 500 euros and im not paying that .
any way managed to find this genuine bimota inlet
ultra rare and only set ive seen for sale .
bimota inlet manifold
and a pair of reed stuffers
like they say its not what you know its who !
PostPosted: Thu Jan 14, 2016 11:37 am
Hi Eyrey! Very nice project!! In an earlier thread, you mentioned that you bought 4 barrels for the v-due engine. I'm looking for barrels, pistons and heads. Do you have some in spare for sale?!
Helmers58
PostPosted: Tue Jan 19, 2016 12:59 pm
I look forward to receive cylinders I bought from you Gary!
Does anyone have some information on porting these cylinders? I have thought about making a radius from the cylinder liner to the transfer boost port, and open up the boost port a little bit. I also want to enlarge the piston skirt windows to match the cylinder liner openings and make a window for the transfer boost port.
Does anyone have some experience with this? See pictures of vdue cylinder below.
Helmers58
PostPosted: Wed Jan 20, 2016 3:27 pm
i look forward to posting then but at £60 thats looking a bit grim until ups wanted £35 so getting picked up tomorrow
bloody post office in uk said 60 and mr behind the counter said half them it will be much cheaper so i went home and re packaged them into 2 parcels and took them back , they then wanted £54 each so 108 quid
im paying for the post so please be patient
i work long hours
ups collecting in the morning but i need your phone number as i said in my email and on pm
PostPosted: Sun Jan 24, 2016 10:45 pm
i changed the rotor for the frp hub and rotor that is made special for the zeel
[/quote]
Where is the rotor photo
[/quote]
PostPosted: Sun Jan 24, 2016 10:46 pm
nearly ready to start ,goes in a week for fairings fitting and they are amazing
just needs a bit of wiring and some fluids
and its brum brum or wingming ming ming
and thats where i am up to .
done a couple of bits of wiring and jubalee clips on rad pipes etc
a few jobs this week like wire up starter motor and get some oil and coolant in it
and a bracket to hold the battery and zeel box in the seat hump
i hope it goes pretty easy with no problems ,it should do its all new
PostPosted: Tue Jan 26, 2016 4:45 pm
Looks very good! If you run the same set-up as me with the oil pump, remember to use oil check valves into the carbs also. Unless, I'm not sure if you get proper lubrication of the big end bearing due to imbalance of the oil supply from the pump. Also warm up slowly before revving ;)
Helmers58
PostPosted: Thu Jan 28, 2016 4:22 pm
Helmers58
going to run on pre mix for first start
do i need to prime the crank feeds ?
PostPosted: Sun Jan 31, 2016 7:28 pm
i got the bike running today ! im well happy with it
bloody throttle cable nipple came off the end just as i was going to start it.
my fault as i cant have solderd it on propperly
any way here is the first start but i cant rev it .
i will post another vid once its cable is mended hopefully tomorrow
ran pretty good to say its not been set up at all !
https://youtu.be/7myBMrqUSQE
PostPosted: Mon Feb 01, 2016 7:05 pm
https://youtu.be/WZ639ScgV8U
PostPosted: Mon Feb 01, 2016 10:04 pm
Job well done, Man, that thing sounds class.. :)
PostPosted: Tue Feb 02, 2016 7:48 am
Congratulations - sounds wonderful !
PostPosted: Tue Feb 02, 2016 11:50 am
Perfect! I look forward so see it dressed in carbon works!
Helmers58
PostPosted: Thu Mar 17, 2016 12:16 am
got the fairings back for the bike and fitted them im well happy
post pics later
