rs500v2 hybrid
Sub forum for V-Due owners and enthusiasts
EYREY1
Re: rs500v2 hybrid
#16 Post by EYREY1 » Sun Dec 20, 2015 11:44 pm
frame is ready for welding , just a patch on the frame spare under it and the 4
mountings , it will have to go again once ive sorted the front ones
got a mate to make me some spacers 1mm wider than the engine so it allows .5 of a mm
each side for powder coating
the spacers make sure the welder gets them spot on width for the engine
EYREY1
Re: rs500v2 hybrid
#17 Post by EYREY1 » Sun Dec 20, 2015 11:51 pm
once i got the frame back from welding i booked it in with kenny at tsa to make me some pipes for it
i know his work as i have his exhausts on my rs250 and my tzr250 3xv ,his exhausts all work very well
but before that i had to make a front engine mount and get a few more bits bolted to it so the pipes would be clear of everything
EYREY1
Re: rs500v2 hybrid
#18 Post by EYREY1 » Sun Dec 20, 2015 11:54 pm
front mount i used an rs250 front subframe and only had to alter the front mount position in one place
it fits like a glove with the 2 spacers ,
a few more bits arrived
cranks are going away for checking while they are out daft not to ,but they seem ok to me but im not a crank expert lol
reg/rec ,generator,pickup
all new
zeel v24 , and ignitech loom kit new
ignition new
brembo goldlines ,ive got re-build kits for these
mph speedo with only 3250 miles on didnt think i would get one
powervalve motor and switchgear
loads of genuine parts all the little clips seals roller bearings etc
that you need to do the job right ! 46 items
RC45
Re: rs500v2 hybrid
#19 Post by RC45 » Wed Dec 23, 2015 6:27 am
Bloody hell mate :)
So you say there are some complete motors up for grabs in Italy?
Talk about an excessively frivolous Xmas present LOL.
Hmmm - think the V-lump will fit in a TZ frame??
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
EYREY1
Re: rs500v2 hybrid
#20 Post by EYREY1 » Wed Dec 23, 2015 2:47 pm
RC45 wrote:Bloody hell mate :)
yes mate 20 of them 130hp dont know about a tz frame though
only just goes in an rs250 frame and thats a bigger bike 7500 euro each i think not sure if you get carbs for that ?
Ade SYM
Re: rs500v2 hybrid
#21 Post by Ade SYM » Thu Dec 24, 2015 9:29 am
I contact Piero re the engines.
The 130BHP are 7,500 euro without carbs but he can supply them along with manifolds
He also has the standard engine with the updates and will take carbs for 5000 euro
Overall a good buy I think
Ade
RC45
Re: rs500v2 hybrid
#22 Post by RC45 » Fri Dec 25, 2015 2:39 am
What's the power numbers on the standard jobs?
I would assume that hey have pipe specs for the 130bhp monsters available.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
EYREY1
Re: rs500v2 hybrid
#23 Post by EYREY1 » Fri Dec 25, 2015 5:05 pm
RC45 wrote:What's the power numbers on the standard jobs?
I would assume that they have pipe specs for the 130bhp monsters available.
ask piero , i can give you some pipe dimentions used on the other rs500 build thread from on here
i go them from the lad that he got the numbers from
mine are tsa and you would have to ask kenny for them as thats his info and i dont have it
RC45
Re: rs500v2 hybrid
#24 Post by RC45 » Fri Dec 25, 2015 6:48 pm
I have an email into Piero. Looks like it was a good thing the guy selling the MAC decided to keep it :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
EYREY1
Re: rs500v2 hybrid
#25 Post by EYREY1 » Fri Dec 25, 2015 9:15 pm
ask him if he will put say 500 $ on the import for the engine or less if not you will get smashed with the big import charges ?
carbs are pretty easy to get and if no inlet manifold but i think there is,
frp make a really nice one but its about 480 euro i think
run it using a zeel v24 box , the ones he sells are fully sorted reliable motors
that can run on premix .
piero is a nice helpful fella ,he will help you all he can
ns86
Re: rs500v2 hybrid
#26 Post by ns86 » Sat Dec 26, 2015 2:04 am
RC45, Link says 2004 was 130hp, 2003 bike was 120 hp. Earlier is less, 2nd link says 110hp. Crankcase issues/crank seals? Aftermarket cases?
Anonymous25/05/2013, 16:26
Turns out that the "fueling problem" is only half truth. Bob Steinbugler at Bimota Spirit found the actual problem - leak prone crankshaft seals!
Makes sense right?! Erratic power delivery with injection or carbs...
He has cast his own case halves to accept a proper beefy 2-stroke crank seal and offers them for sale separately or will rebuild your entire engine. -- JT
http://www.odd-bike.com/2012/11/bimota- ... imota.html" onclick="window.open(this.href);return false;
http://www.motorcycle.com/manufacturer/ ... 14291.html" onclick="window.open(this.href);return false;
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
EYREY1
Re: rs500v2 hybrid
#27 Post by EYREY1 » Sat Dec 26, 2015 4:09 pm
ns86 my bike has been modyfied with bigger better crank seals
piero swapped all the cases on all the bikes made as he had new ones made himself
the engines he has are last generation fully modified with new cranks , seals,cases ,barrels, con rods
as it gets rid or the oil pump feeding oil down the web centers to feed sealed big end and little end bearings
and does it like a normal 2 stroke engine it can run pump or pre mix
things have moved on a bit since that was written
RC45
Re: rs500v2 hybrid
#28 Post by RC45 » Sat Dec 26, 2015 5:37 pm
EYREY1 wrote:ns86 my bike has been modyfied with bigger better crank seals
The VDue's themselves where starter-motor setups rather than kick starters, correct?
Are the only options for electrics, carbs and pipes 3rd party bits?
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
EYREY1
Re: rs500v2 hybrid
#29 Post by EYREY1 » Sat Dec 26, 2015 7:22 pm
you can buy electrics new but ecu is like 1k without loom
starter motor only i just got 1 new for 220 euros but engine would come with one
ask piero how much with electrics he has everything .
but zeel is better and fully programmable as well
guido in germany does full loom with zeel with maps already in plug and play
i used mk2 rs 250 loom as i wanted those clocks , it was the easyest way to add zeel to rs loom just same as putting a zeel on rs250
uses same wires but fires both coils at same time for the bimota engine
you can get jollymoto pipes but they are for v due bike and cant see them fitting anything else as 1 pipe goes up through the hole where rear shock goes
i have pwk carbs on mine
RC45
Re: rs500v2 hybrid
#30 Post by RC45 » Sat Dec 26, 2015 8:05 pm
Well, I would be after a track GP replica setup, so only an analog rev counter would be needed for instrumentation and I suppose only a kill switch.
No need for dash idiot lights or any other street lighting/signaling bits.
Sounds like a custom/cut down Zeel setup would work.
Pipes would be best custom made to the required specs. If I was going to use the motor on the NS500 replica, I would try get the pipes laid out similar to the NS500, with the lower pipe coiled up under the engine and the upper going out under the seat.
I have a set or HRC RS500 pipes to use as patterns.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
