wits end with RG500
Sub forum for RG400/RG500 owners and enthusiasts
mark b
Re: wits end with RG500
#16 Post by mark b » Tue Aug 30, 2016 6:05 pm
Spent some time today going through the electrics, found 2 wires with cover worn through, sorted them and cleaned more joints up, now have good spark on all plugs :smt023 there still seems to be an over fuelling problem as plugs get very wet and access fuel around disc valves and in air filter pipes.
I set the float height at 17mm without gasket and need some info on jet needle e clip setting just to confirm that is set right.
I put in new genuine needle valve's as well.
One other thing which was happening when I was kicking over, was it would back fire occasionally ?
All your help is very much appreciated :smt023
suzsmokeyallan
#17 Post by suzsmokeyallan » Tue Aug 30, 2016 9:09 pm
Ah so coil wires in the harness issues rear their ugly heads again, good news thats fixed then. First off remove those air filter pipes and drag out the gauze discs located in them and throw them FAR away if they are still in there. Go to Rick Lances site Lance gamma for the carb set up and cable adjustment ritual, its a long read....
Backfire is possibly due to prolonged over fueling trying to get the bike to start, or possible timing issues. I can only hope the crank gears are in alignment to each other and that the disc valves are set up correctly as well.
Drop in some new hotter B7ES plugs for now, so when it finally starts they can cope with the excess fuel in the cases. They will also quicken warm up of the engine and not foul while you fiddle around with adjustments.. Once its sorted out and running well to throttle inputs swap out to the 9s.
With so much wrong on this bike it appears many people in the past tried solutions to fix a problem that was never anywhere near where they were botching it up,, I mean working.
You will be happy when its finally solved.
The list:
68 Suzuki U70
69 Suzuki T500 MKII
72 Suzuki GT750
74 Suzuki GT750
75 Suzuki GT750
75 Suzuki RE5
76 Suzuki GT750
76 Suzuki TS400
81 Suzuki GSX1100
86 Suzuki RG500 x2
88 Honda CR500
92 Honda CBR900RR
98 Suzuki GSF1200 x3
15 Kawasaki Ninja H2
bogey
#18 Post by bogey » Fri Sep 23, 2016 9:54 am
Hi,
How is your battery. have heard of faulty batteries causing all sorts of weird problems!
Hope you get sorted.
regards
B
Barrienunn
#19 Post by Barrienunn » Wed Nov 23, 2016 8:33 pm
i had a simular problem on a RGV VJ22 run fine until i put it back together and it turned out to be a connection under the seat .. took me weeks to find it after striping the carbs ect
hope your sorted .. i get my gamma tomorow ,,, Happy Days
mark b
#20 Post by mark b » Sun Apr 17, 2022 5:39 am
Just an update after trying everything it turned out to be an intermittent fault with the CDI unit which I had originally tried swapping but obviously the one I swapped was also faulty 🙄
Motopilot
#21 Post by Motopilot » Sat Apr 23, 2022 4:31 pm
I just ordered a Zeeltronic unit to try. I have had some similar issues. I’m hoping to eliminate the ignition issues and being able to tune the bike a bit with this.
I hope you find a solution soon.
Scott
Canada
