RC45's RG500Γ XR45 Project - Full XR45 Bodywork located!
Sub forum for RG400/RG500 owners and enthusiasts
ns86
Re: RGV250 tank on 500 frame & other questions?
#16 Post by ns86 » Wed Feb 04, 2015 2:37 am
I have 2 fairly beastly RGV500's myself and you're right, more than several pocket's full of cash went into them. One running Jolly's one running JL's. The numbers that matter in this comparison being the difference between the 400/500. Just trying to figure out what route to go myself. When they say 59hp @ crank for the 400 what would you expect the cheapest conversion [bore & pistons]to 460cc to cost and output? I assume some exhaust restriction on the 400 to account for the huge difference in spec HP , 59/95. So apples to apples, RG400/460 rejetted with RG500 stock pipes compared to stock RG500? Mark350lc's resleeved 500/5 port puts out 100hp with significant porting/pipes and your rebarreled 550/7 port puts out 127hp with porting/pipes. Seems your's is higher output/cc. 50cc=27hp!
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
begbie
#17 Post by begbie » Wed Feb 04, 2015 9:02 am
The 400's were only restricted by the 135 main jets (500's ran 120's) the exhaust dimensions are the same apart from the stingers which are 2mm smaller in dia due to the smaller bore size of cylinders.
the 400's power (once 120 mains are installed) is pretty much in line with the 500 cc going by my own dyno findings cc, 500cc divided by 5 = 15hp per 100cc, 15hp times 4 = 60.
I have no personal expirance with 460 over bores but with the right pipes, prog ign with advancer and optimsing CV / squish I would be aiming for 80/85 RWH. It would be an intresting project.
RC45
Re: RC45's RGB500 XR45 Project
#18 Post by RC45 » Fri Feb 06, 2015 3:27 am
Well it's on now.
RG Frame, RG swinger, 86 GSXR front end, RG500Γ XR35 dash bracket, RG500Γ Gamma XR45 tail piece, classic RGΓ XR style upper fairing, Sugaya pipes, RGΓ temp gauge inbound.
I am going for classic look here. Not sure about engine yet - maybe tuned big bore 400, seems the more economical way to go.
I am on the hunt for 2 piston race brake calipers. When folks upgraded their race bikes to four piston calipers int he early 80's, did they throw the old 2 piston units away? Struggling to find them anywhere. I think I will even run the brakes ahead of the forks.
On the hunt for someone to make the bespoke RGΓ embossed alloy tank :)
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
OW69 Daytona 200 Replica - 784cc Monster
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
ns86
Re: RC45's RG500Γ XR45 Project
#19 Post by ns86 » Fri Feb 06, 2015 3:11 pm
This is an informative link about the 400 engine. Just learning/deciding myself. Bored 54mm 400 uses 1985 CR125 pistons, Pro-X. Pistons require machining for small end clearances meaning wrist pin diameter I assume? Also requires decking of cylinder and re-profiling of head. Rear transfer ports need correcting and rotary valves need to close later. Durations are in the thread etc.
http://www.rgv250.co.uk/forums/index.ph ... -chambers/" onclick="window.open(this.href);return false;
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
RC45
#20 Post by RC45 » Fri Feb 06, 2015 6:53 pm
I am trying not to blow my entire modded Gamma Square Four engine budget on this....
Brand new never used RGB500 tank.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
RC45
#21 Post by RC45 » Fri Feb 06, 2015 7:09 pm
ns86 wrote:This is an informative link about the 400 engine. Just learning/deciding myself. Bored 54mm 400 uses 1985 CR125 pistons, Pro-X. Pistons require machining for small end clearances meaning wrist pin diameter I assume? Also requires decking of cylinder and re-profiling of head. Rear transfer ports need correcting and rotary valves need to close later. Durations are in the thread etc.
From what I have been told, the re-sleeved 400 barrels are not ideal - they are significantly heavier, the new bigger sleeve shrouds what little port volume is left and I believe I was told the power valves tend to bind due to liner expansion when the motor gets hot and is run really hard on track.
Bored stock 400cc barrels or retrofitting 500 barrels to the 400 cases appear to be the most direct and most cost effective ways to get to where I am trying to go. With the bored 400 option being the slower lower power but cheaper alternative.
I think I am going to focus on the roller and get it all the way to where I need it and then just gamble on a suitable donor engine appearing on my doorstep one day :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
begbie
#22 Post by begbie » Fri Feb 06, 2015 7:26 pm
Or if budget allows I know the item has ended but they are still available new .
http://www.ebay.co.uk/itm/Brand-New-Cyl ... 1462856559" onclick="window.open(this.href);return false;
RC45
#23 Post by RC45 » Fri Feb 06, 2015 11:46 pm
I guess I am going over bored 400cc for the first version of the engine. RG400 cases, cylinders, cranks and heads in-bound. This lot was less than the cost of the 500 cylinders - including shipping.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
begbie
#24 Post by begbie » Sat Feb 07, 2015 6:48 pm
I think thats a wise choice, and the way I would if building another.
Look forward to following your progress.
ns86
#25 Post by ns86 » Sat Feb 07, 2015 10:00 pm
A 50/50 chance I will be going that route myself. No re-sleeving for me. Even if I get barrels at cost through my friends Suzuki dealership they will be a minimum $1500 for the set. That will go a long way toward building a big bore 400. Having 2 500's already there is a certain allure to it as well. Still undecided though since $2000 may well get me to a full stock 500 engine if I get all my parts at cost and machine my own heads and upper cases. In my case my bike is a registered RG500 roller that was a donor for one of my hybrids and could be a very nice stock bike again. For me it would be wise to make it a stock RG500 since I don't have one to complete my stock RG/RZV/NS collection. I look forward to your build as usual!
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
RC45
#26 Post by RC45 » Sun Feb 08, 2015 4:50 am
I like the look of this bike. Now to find a set of RG500 XR45 brake rotors.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
andy
Contact:
#27 Post by andy » Mon Feb 09, 2015 4:30 pm
In the event any of you are looking for a 500 gamma motor/carbs/electrics I have one nearing completion.
Best to drop me a note thru the site, http://www.alienracing.net" onclick="window.open(this.href);return false;
RC45
Re: RC45's RG500Γ XR45 Project - HB Cigarette Decals??
#28 Post by RC45 » Wed Feb 11, 2015 1:02 pm
Lucky Strike, Marlboro, Rothmans etc... sponsor decals for lots of brands of cigarettes, but finding HB decals is proving a little difficult.
Any ideas?
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
rd84
#29 Post by rd84 » Thu Feb 12, 2015 2:16 pm
It might be possible to use the decals from a model motorcycle to use as masters for full size ones such as these........
http://www.spotmodel.com/product_info.p ... s_id=13907
Probably do an high resolution scan of them and then correct, enhance or change in Photoshop as required.
RC45
#30 Post by RC45 » Thu Feb 12, 2015 6:31 pm
I have no problem with scanning and cutting vinyl on the cutter. Stripes, number boards and major graphics elements etc. - but for multi-colour sponsor logos and the like I prefer to use actual screen printed stuff. Just looks the part.
I guess its off to the local printer then.
*edit*
I just sent an email off the British American Tobacco - I think they own the brand, so hopefully they respond that they have stickers galore for sale :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
