Hi Steve would you know where these fit.
Thanks Ron.
Damper
Re: Damper
Upper exhaust heat shields (Ref # 25) that mount to the rear sub-frame -
http://www.rzv500r.net/Tech_docs/47X-PL ... age_37.jpg
The parts fiche calls out for a quantity of six (6) of them?
Hopefully Steve can confirm/explain...
Re: Damper
Hi, those protectors and dampers aren't listed in our parts book,
Thanks Ron.
Thanks Ron.
Re: Damper
First year (47X) bikes only. You won't find it in the other parts lists.Ron57 wrote:Hi, those protectors and dampers aren't listed in our parts book,
Thanks Ron.
I believe the quantity is actually 8.
- jackson.40
Re: Damper
Here you go........................
They fit on the underside of the shield as per the shield in the bottom of the last photo.(8 in total)
Only fitted on first production run bikes(but not the RZV500R)
Re: Damper
Hi, It's great to get on to this forum site and get all your issues sorted.
Thanks Ron.
Thanks Ron.
