Rubber foam parts
Got some stuff you need to move out? Do it here! Please, NO vendors
Speed Freak
Rubber foam parts
#1 Post by Speed Freak » Wed Jan 04, 2017 7:00 pm
Hi,
as already shown im my restoration topic I have made a set of rubber foam parts.
Today I got the first full sample set, on the picture together with the original Yamaha part:
Cut edge is good now, just have to work on the dimension accuracy of the 5mm thick parts. Means I need to go there on a saturday and optimize the cutting process together with the guy who is doing them for me...
Material: Fuel and Oil resistant rubber foam with a strong adhesive on the backside.
Part numbers:
- 1GE-1446R-00 (3,50€/pc) => air filter to carb rings (4 per bike), still available from Yamaha
- 47X-2173M-01 / 47X-2173N-01 (5€/set) => the 2 pieces on the rear of the frame (one of each per bike)
- 29N-21747-00 / 5G3-82126-00 (1€/pc) => pads on the oil tank (one of each per bike)
- The big seal (5€/pc) which seals the air filter case center to the "ears", never available from Yamaha (2 or 4 per bike depending on if you want to remove the rivets or not)
I will also buy some rivets which will work for connecting plastic parts and add 4 of them if needed.
They should be ready for shipping in ~4 weeks, depending on when I will find time for the optimization.
Worldwide shipping is no problem, this parts fit into a cardboard envelope (0,5€) + shipping costs according to http://www.post.at/en" onclick="window.open(this.href);return false;
Let me know what you need.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
BigGuy
Re: Rubber foam parts
#2 Post by BigGuy » Thu Jan 05, 2017 9:54 pm
Hi Speed Freak. Happy new year! I am interested in the - 47X-2173M-01 / 47X-2173N-01 (5€/set) => the 2 pieces on the rear of the frame (one of each per bike) cut outs. Roughly speaking what would the pair be worth? I'm in Ontario, Canada, N0R 1K0.
Thank you.
Shawn
Shake "N" Bake!
podman
#3 Post by podman » Fri Jan 06, 2017 5:07 pm
Can I pay by PayPal?
Would like "The big seal (5€/pc) which seals the air filter case center " x 2..price posted to the UK ,please.
(PM if you wish) Thanks
Vin
#4 Post by Vin » Sat Jan 07, 2017 6:52 am
Hi Speed Freak,
I will take 4 x Big seal (with rivets if possible) and both frame pieces please, pm me price incl postage and can also pay via paypal if preferred?
Regards Vin
Bengt Weil
#5 Post by Bengt Weil » Sun Jan 08, 2017 9:04 pm
You've got PM - another order request for frame pcs and two big seals - Thanks!
Paulrs
#6 Post by Paulrs » Thu Jan 12, 2017 7:12 pm
Hi Speed Freak, two of the big seals and both the frame pieces for me please.
Out of interest have you looked at making the large foam profiles that stick on the outer surface of each air duct.
Regards
hbcsd
#7 Post by hbcsd » Thu Jan 12, 2017 11:22 pm
Hello, put me down for 4 carb to air box, 2 frame, and 2 big seals please!
cainpole
#8 Post by cainpole » Sat Jan 14, 2017 10:45 am
I need 2 of the frame strips.In a previous post you mentioned float valve needle seat O rings made from Viton. Where do get them and what sizes are needed for rz 500. thanks!!!
Speed Freak
#9 Post by Speed Freak » Sat Jan 14, 2017 2:27 pm
Everything is finished today
Amount of parts which are still available:
- Big air filter case seals: 0, but there is a bit material left over for maybe 4-5pc
- Airbox to carb rings: 8 (2 sets)
- Frame pieces: 7 sets
- Oil tank: 10+
Regarding the big foam pads on the outside of the case I will probably do them as I`m not really happy with mine (they have some chips) but not at the moment.
Will need some time to investigate which material they are and they also need a different cutting method.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
#10 Post by Smoker » Sun Jan 15, 2017 8:41 pm
If these parts are NLA from Yamaha, I would be happy to buy a complete set. :smt045
Speed Freak
#11 Post by Speed Freak » Thu Jan 19, 2017 3:18 pm
Found time to do the shipping stuff today...
All parts which are paid will go out tomorrow, all with registered letters will get a tracking number.
To all who get rivets: Delivery time ~2 weeks.
I will let you know when they are here.
I have ordered another production run of airbox seals (rings and the big seals), will be finished in maybe 2 weeks.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#12 Post by Speed Freak » Wed Jan 25, 2017 5:15 pm
Rivets arrived today and the function of them is perfect.
Before you can pull out the rivets the plastic will break.
One test rivet with head drilled off:
For the riveting process it`s good to have 2 more hands and it shouldn`t be done in the cold garage.
The foam is getting stiffer when it is cold, so I recommend to work at minimum +20°C
First you have to put the foam gasket onto the backside of the funnel.
Then put it onto the outer air filter case and compress the foam (thats why you need 4 hands).
Holding the funnel in place with the compressed seal you can put in the rivets.
It also works without compressing the foam as the rivet is pulling the 2 parts together, but I think there is a small risk that the result is not perfect.
Then please push out the pin of the rivet.
I would not recommend to leave them in the rivet, even if they are not loose.
It`s simply to ensure that they will not fall out later due to vibration.
If this pin is falling out when the bike is running it will directly enter the engine thru the carbs!
There is not much force needed to push them thru, the rivet itself doesn`t get loose.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#13 Post by Speed Freak » Wed Jan 25, 2017 6:04 pm
Update:
6 big air filter box seals available again.
All other parts are also available.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
#14 Post by Smoker » Thu Jan 26, 2017 5:53 am
Cool. I'll take a complete set.
I don't need them now, but maybe in the future.
If you PM me the cost, I'll Paypal you some cash.
darrowco
#15 Post by darrowco » Thu Jan 26, 2017 6:47 pm
1 complete set for me pls! Let me know payment details via PM, thks.
