Joined: Sun Mar 14, 2010 10:30 am Posts: 51 Location: St Albans UK
These look perfect for a long term YZR 3MA project I'm building. It does use the stand 3MA bodywork, but would the stuff work too, or is the fairing too wide? I know your bike Alex is a widened 3MA derived frame, but any advice would be welcome.
Joined: Fri Aug 19, 2011 5:18 am Posts: 1561 Location: Houston, Texas.
dbcjmc wrote:
Hi There! I'm new to the forum. Will this fairing and seat fit the RZV500R? Do you still make and sell it? Price to ship to USA Zip Code 95124?
I am planning on using the fairing I purchased from Alex on a custom framed bike, but I rough fit the belly-pan to my my RZ500 and it appears to be a decent fit. Alex has already cut the NACA duct to fit the RZ500 waterpump.
The bellypan has also been extended to fit a taller setup so the fairing should be easy to make fit to the RZ500 frame - I am going to trim it back to YZR500 dimensions.
The tail piece may require a little bit of work if you have fatter aftermarket pipes. The seat unit did not fit over the Jolly Moto upper pipes on my bike.
I have no idea how it will fit over stock upper pipes.
_________________ TZ500V/OW53 Track bike YZR500 OW81 Clone OW69 Daytona 200 Replica - 784cc Monster NS400 Track Bike RS250R NF5 TZ250T 2KM TZ250B 3YL TZR250 3MA Track Bike 427ci C5 Z07
Joined: Sat Oct 24, 2009 5:11 am Posts: 270 Location: Modena (ITALY)
Hi Smoker
one set of fairing is directed in united states, one member want to put it on a stock rzv frame we are all impatient to see how it fit and final result.
about my project i had some big troble with my job and my mind goes far from bikes for a while last winter i built an RGV-RG500 for a friend, almost ready now and i'm still working on Bimota V2 aprilia framed project (for another friend)
step by step i'm trying to come back at my usual hobbies
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
