RZ500 lightweight flywheel conversion
Vendors can post special deals in here - Please, VENDORS ONLY
geosot
#1 Post by geosot » Mon Sep 20, 2010 9:59 am
EDITED 20.11.2010
Lightweight generator, i.e. flywheel, windings (stator) and pick up coils (all from RGV250 VJ22), adapter plate from billet 7075 aluminum, Ignitech DC-CDI.
The generator supports lights and all electrical "appliances" of a road bike.
Kit works only with a DC-CDI; the only adjustable (via serial or USB port & available from the shelf) DC-CDI that I know is Ignitech.
The flywheel can be machined upon request to save some more weight.
The weight saving is about 50-60% of rotating mass. A plus is the extra space for bigger carbs.
Fitting of the kit requires a minimum of mechanical and electrical knowledge and a slight modification of wiring terminals.
geosot
#2 Post by geosot » Sat Nov 20, 2010 7:05 am
Sumitomo sealed wiring terminals can be supplied upon request with the kit.
Coils (two with dual outlet or four with single outlet) can be supplied upon request with the kit.
Servo (dual stage) can be supplied upon request with the kit.
Race wiring (supports battery, on off switch, PV controller & servo, CDI) can be supplied upon request with the kit.
Road wiring (supports all electric functions) can be supplied upon request with the kit.
Both wirings are new and with sealed Sumitomo terminals.
wolfgangh
#3 Post by wolfgangh » Mon Dec 27, 2010 9:09 am
George,
Borut (Zeeltronic) has DC-CDI as well, have you tried his?
Do stock RD500 cois work with IGNITECH or ZEELTRONIC DC-CDI as well or is change of coils reuqired?
geosot
#4 Post by geosot » Mon Dec 27, 2010 10:16 am
wolfgangh wrote:George,
Yes
wolfgangh wrote:or ZEELTRONIC DC-CDI
I suppose yes, since PDCI-20V is for coils with primary resistance 0.3-0.6 Ohm
wolfgangh wrote: as well or is change of coils reuqired?
NO BUT
Market offers a plethora of coils with primary resistance 0.3-0.6 Ohm at prices from 100 US $ the set (complete with wires/caps). Why one has to stick with a pair of 25 year old coils?
