We modify the front mounts of the rear shock absorber, moving the shock approx. 8mm backwards. This increases the rear ride height (measured at the rearwheel spindle) by approx. 1,5". The mounts come fresh powdercoated black. You send us your original mounts and we return modified ones in exchange (from stock). This is the most likely the most cost effective ride height increase you can buy.
See more details in our webshop at http://hromada.www14.estugo.de/Chassis/ ... rease.html
Ride Height Increase Modification
