Oil leak
Moderators: smurph, rztom
Locked
jimmy
Oil leak
#1 Post by jimmy » Wed Nov 09, 2005 3:16 am
Got an oil leak from g/box side cover. do you have to remove water pump to get the side casing off? or should it come off with the water pump.
<br>
<br><hr size=3 width=75%><p>
jlm22@iprimus.com.au
Wyn Belorusky
Re: Oil leak
#2 Post by Wyn Belorusky » Wed Nov 09, 2005 4:16 am
You have to take the water pump off to get the clutch cover off, there's a mounting bolt hidden by the water pump.
<br>
RZVWyn@aol.com
Andrew UK
Re: Oil leak
#3 Post by Andrew UK » Wed Nov 09, 2005 6:21 am
Wyn<br>I know you have to remove the water pumb, but if I remember correctly there are some of the water pump bolts that don't have to be removed. Is this right???<br>Andrew UK
<br>
andrew.lord@vacon.co.uk
Wyn Belorusky
Re: Oil leak
#4 Post by Wyn Belorusky » Wed Nov 09, 2005 3:18 pm
That is correct, off hand I forget which ones though.
<br>
RZVWyn@aol.com
Locked
