Does anyone know the part number for the R1 clutch fiber plates that are the same as the RZ's??<br>thanks
<br>
<br><hr size=3 width=75%><p>
geakins@adelphia.net
R1 clutch part number
Re: R1 clutch part number
From Barnett (www.barnettclutches.com) the R1 and RZ fiber plates are the same number YPK-5 - 7 total - the r1 uses an 8th friction plate that is different from the rest - the RZ just needs the 7 that are the same - 98-03 R1.<p>The steel plates I have not compared - they list different numbers - RZ is YP-20-15 6 plates, R1 is YP 15-20 not sure what the difference is between the 2 parts, but the YP-20-15 is readily available.<p>I am pretty sure EBC last year listed the CK2305 kit for something else, but has since changed the listing to to still have a line in the catalog, but lists it as no fitment.<p>I might have to order 1 R1 steel plate just to find out what is really different.<p>Rob
<br>
roadkillrobert@yahoo.com
<br>
