500 Two-Stroke Tech Forum Index 500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Log in to check your private messagesLog in to check your private messages
Log inLog in  RegisterRegister
Profile  Search  Memberlist  FAQ  Usergroups
Track exhausts.
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic    500 Two-Stroke Tech Forum Index -> Custom Projects/Restoration
View previous topic :: View next topic
Gary Papesh
PostPosted: Sat Nov 10, 2007 4:37 am    Post subject: Here is a much cheaper alternative. Reply with quote
Check out a program called "Cone Layout". It was designed for pipe building and is pretty easy to use. You can input the diameters ,length and degrees of angle of either end of the cone. Then you can save the file or save as an dxf. file (drawing exchange format). Then you can send the files to your local sheet metal shop for use on their cnc plasma cutter( Vulcan,Cybermation). Or you can print the profile on paper and cut it with snips. and The program only costs about $40.00 U.S. You can even download a free trial( that's what I did.) Now learning welding seems easy does'nt it! Sincerely, Gary Papesh.
www.pulserate software.com
Very Happy
Back to top
View user's profile Send private message Send e-mail
Blackshaheen
PostPosted: Mon Nov 12, 2007 1:50 am    Post subject: Reply with quote
Nice one Gary.
I hadn't thought to measure up my pipe before I cut it because I'm a Muppet! I still have one uncut upper and I haven't touched the lowers yet so I will measure them up and save the information.
Shaftoflame...you are dead right about cutting the cones. I have started one of the upper pipes and cutting the headers has been no problem due to their small diameter but the fat mid sections have been a bitch like this just to get a clean cut regardless of the angle. I have already stuffed up one cut and have simply butted the pipe back together in the same position Sad One more weld I didn't need!
I have to come up with a better plan.
Froth, there are no instructions with the pipes and no rules really. They come as a straight pipe (if you just welded them as is) of a particular tuned length. You can cut them to run as you please as long as you take care not to alter the tuned length of the pipe too much (by cutting bits out and then throwing them instead of adding them back into the puzzle) and also that you make sure there are no angles in the pipe that will affect gas flow. I had one angle in my header which put it in the direction I wanted but it was too sharp so I re-cut it and softened the bend as a result for better flow later. I spoke to Dave Swarbrick about the tuned length of the pipe and he said that it isn't an overly 'pipey' or 'short' pipe and that I need not worry about losing a centimeter or so in the over all length. I estimate that this is how much material I will lose as filings when I cut. Obviously the more cuts I make the more material I lose.
I'm struggling a bit right now with cutting and learning as I go but I haven't destroyed them yet...yet.
Pics to follow when I get a bit further.
D.
I will not tighten bolts after drinking beer, I will not tighten bolts after drinking beer,I will not tighten bolts after drinking beer,I will not...
Back to top
rd84
PostPosted: Mon Nov 12, 2007 5:28 am    Post subject: Reply with quote
Hi,
I've yet to try the technique but I was told that using a large diameter jubilee clip as a cutting guide helps. - I'm going to work on a old set of mild steel pipes for practice later this year - so if you gain any insight into doing your pipes it would be nice to hear about what works well and what doesn't.
Blackshaheen wrote:
Nice one Gary.
D.
Back to top
Lynton
PostPosted: Tue Nov 13, 2007 4:33 pm    Post subject: Reply with quote
If you get the Australian "MOTA" 2 stroke software it has pipe development and building sections. With the buildong you put in the bends you want, the thickness of the metal, the number of sections and it then prints out the templates full size. its great, no cutting up a straight pipe. There is a demo version on their site.
lynton
http://www.iwt.com.au/MOTA.HTM
Back to top
vma500
PostPosted: Wed Nov 14, 2007 11:50 am    Post subject: Reply with quote
try this ''cone calculator 1.3'' .......for free Very Happy
http://www.rd350.nl/archief
goto software
rgds
M.
Back to top
Andrew
PostPosted: Wed Nov 14, 2007 12:39 pm    Post subject: Reply with quote
Forming and cutting the sheet metal ok, you also need a set of rollers that have the conicle attachments which allow you to roll the cones. Not everybody has these.
Andy (UK)
RZV500R
FRC
Faster Faster !!!
Back to top
Blackshaheen
PostPosted: Sun Nov 18, 2007 7:02 am    Post subject: Reply with quote
OK Folks,
HUUUUUGE change of plan. I can be such a Muppet!
I have no bodywork for my project as yet. I started cutting the pipes in Jolly Moto style, ie exiting before the oil tank and returning under the bike at the sub-frame. I have no oil tank either as I will be running pre-mix (some time before I die of old age I hope!). And then it happened...a Triumph T595 tail section fell into my lap. Offered it up to the bike and with some 'cut and paste' I think it's going to look good and work out fine. The Jolly Moto pipe arrangement wont fit under it though (IDIOT!). I am now going to run the pipes straight out from the barrels and through my non-existent oil tank. Bottom line is that I've wasted some time but everything will still be good. I am putting any pipe-work on hold until I have the tail fitted correctly and only then will I be able to see how best to arrange the pipes.
Idiot? Yes I am.
Thankyou and good night.
Back to top
simon#51
PostPosted: Sun Nov 18, 2007 5:40 pm    Post subject: Reply with quote
Hi guys,
just joined this site, so hello to everyone, im building a track 500 at the moment, been doing it for 3 years. changed front and rear ends 3 times but finaly went with yamaha r6 2006 front and rear ends yzr500 1996 bodykit got jollymotos on it at the moment but need to recut and route the top pipes, they work really well with the terry shepperd tune allthough its still running standard carbs, im going for 32mm mikunis and zeeltronic cdi and pv control. there awsome!!.
Went out for a ride on my mates 500 yesterday (what a tool) 115 bhp at the back wheel, 4th gear wheelies no problem, tons of mid range pulls all the way up to 11,000 revs. felt much quicker than a gsxr1000 k5.
he's got swabricks massive tune 32mm mikuni and zeeltronic boxes.
check them out @ www.zeeltronic.com
will post some pics of my bike soon.
cheers simon.
sharris
Back to top
rztom
Site Admin
PostPosted: Mon Nov 19, 2007 10:24 am    Post subject: Reply with quote
Hi Simon - welcome to the group! Cool
Back to top
Shaftoflame
PostPosted: Mon Nov 19, 2007 7:30 pm    Post subject: Reply with quote
Mr Blackshe - and then my memory fails - never look on somethign like you are doing as a mistake - it is always a chance to learn, and your postings suggest that you are learning all the time - you have ideas and then they change, but you are making them happen - just post the pics.
R
Simon Where in SOuth Wales are you - I am over Port Talbot way
R
Dreaming is not a failing, it is what makes us climb bigger mountains, make better bikes and love. However it can take up an inordinate amount of time...
Back to top
Jeff B
PostPosted: Mon Nov 19, 2007 8:49 pm    Post subject: Reply with quote
Blackshaheen wrote:
OK Folks,
Idiot? Yes I am.
For what it's worth, I have my upper Jolly Moto's mounted on the wrong sides and sideways. Instead of the pipes coming together and then apart, they go down, up and straight back with the stingers modified to bring the silencers back together. I have a Honda RS250 seat mounted a couple inches above the subframe area. It worked great, but the seat does warm up at stop lights.
Back to top
Shaftoflame
PostPosted: Tue Nov 20, 2007 9:23 am    Post subject: Reply with quote
Jeff B wrote:
Blackshaheen wrote:
OK Folks,
Idiot? Yes I am.
Ok where is the pic for those of us hard of thinking?
R
Back to top
simon#51
PostPosted: Tue Nov 20, 2007 3:43 pm    Post subject: Reply with quote
I live in barry, did steve willis paint your 500 not so long ago. coz he doe's a lot of work for me, i own gp motorcycles in pontypridd,
cheers jeff, i'll try that routing coz it will be a crime to chop those pipes as they work really well, iv' tried lomas pipes and there's no mid range atall.
yes a pic of your pipes would be nice, and if anyone is interested in jollymoto pipes im' an agent for them and can offer discount for club members!!!!!.
ill' post some pics of my bike soon, iv' decided to go with norick abe rep as iv got the geniune marlboro bodykit from 1995, its even got the morlboro team roberts and norick stickers on it no9.i was going to keep them as memrabilia but sinse his death i thought it would be nice to build a replica of this.
what do you guts think!!!!.
cheers simon
sharris
Back to top
simon#51
PostPosted: Tue Nov 20, 2007 3:46 pm    Post subject: Reply with quote
SORRY I MENT GUYS,
sharris
Back to top
rztom
Site Admin
PostPosted: Tue Nov 20, 2007 10:23 pm    Post subject: Reply with quote
Simon - well, this "guy" who speaks from his "gut" thinks that's a GREAT idea... DO IT..!! Cool
Oh, and make sure you post pics - we all luv pics....
Back to top
Display posts from previous:
Post new topic   Reply to topic    500 Two-Stroke Tech Forum Index -> Custom Projects/Restoration All times are GMT - 4 Hours
Page 4 of 7
You cannot vote in polls in this forum
phpBB "skin" by DewChugr
Powered by phpBB © 2001, 2005 phpBB Group
Anti Bot Question MOD - phpBB MOD against Spam Bots
Blocked registrations: 12276
